11.03.2008, 09:29 AM
did you measure to make sure that battery will fit Joram? I had the FP 5s 5000mah and with the shims in to make the chassis wider and a 1515 with 18t pinion it was a perfect fit and no room for another cell. not saying it wont work for sure just saying measure before you spend all that money to make sure.
Nitro?? BL rulezzz
11.03.2008, 09:36 AM
it will fitt:
http://www.flightpower.be/eshop-prod...0-6S1P-4500MAH
it is smallest 45mm. I got 5cm space with spacers and highed motormount. I measured the distanse to the spur with an 13tooth pinion, will be more tooth so will fit..
Greetz,
Joram
Standard is not an option!
Nitro?? BL rulezzz
12.29.2008, 11:50 AM
finally an update:
Bought these very nice suspension arms:
http://www.rc-monster.com/proddetail...-12000&cat=109
In about 1.5 week i order the FLM bulkheads en shocktowers.
The CC 2200kv motorcombo will be used and a 6s lipo for some powerrr.
BTW, 6s will fit with the spacers installed, close, very close but it fits!!
Greetz,
Joram
12.29.2008, 11:57 AM
i would have bought the bulks now and waited on the arms. the arms are super expensive, but hey if you have the money why not,  Glad to hear the 6s fits as well.
12.29.2008, 12:25 PM
...nice build...I too like the colour scheme and you woke me up to that body...I didnt know it existed :D
...Your wing mount works well and I might just have to steal that method :D its the easiest mount I have seen yet...
...One of your pictures, with the body in the foreground and the body in the background looks REALLY good :D I made it this weeks wallpaper on my PSP :D Great job...
Nitro?? BL rulezzz
12.29.2008, 02:20 PM
Yeah well, i sold my boat and with that money i bought the arms:)
I looked at the measures from some 6s 5000mah lipo's and it fit's on 1mm....
Going to buy the motor first and then i can see the real space what's left for the lipo. Just in case 6s wont fit, i haven't bought such an expensive lipo
Ehm, why making a difficult mount when it can be done easily
I think i make a new one because of the flm shocktowers, this wont fit because these mountingholes are based on the original towers...
btw, how is my english? I think it sucks
Keep ya updated!
Greetz,
Joram
12.29.2008, 05:19 PM
i've heard these arms are absolutely indestructible... what mah 6S lipo you got? i've measured so i can get a polyquest 6000 in there...
***edit ***
sorry - didn't read ahead first - 5000mah -lol- What brand? =)
ur english is good man, i wouldn't be worried! Try and imagine one of us trying to speak in your native tongue - bet ya dont feel so bad now huh?? -lmao-
Nitro?? BL rulezzz
12.29.2008, 06:03 PM
Polyquest 6000Mah 6s wil fit too yes, maybe i buy them:)
Greetz,
Joram
Nitro?? BL rulezzz
01.01.2009, 07:48 AM
Another update, a order from Liquid rc.
I'm switching the plans for the motor. I'm not going to use the 2200kv CC combo! I'm going too use a Savöx 2000kv motor. Maybe you have never heard of it that's because it's quite new on the market. It's the OEM mark of Team orion, same stuff only the OEM product from the factory.
I'm too going to use a servo from them, 20 Kg with titanium gears and BL motor inside...
Here a cataolgus from savöx, it's not actual because the 2000kv isn't in it, only the 1000kv but you have an impresssion from what
they make!
http://www.savoxtech.com.tw/images/catalogue.pdf
Greetz,
Joram
01.01.2009, 05:08 PM
man i wish i was paid the same amount i get now, but in euros -lol-
The servos look the goods, they are fast!! http://tw.youtube.com/watch?v=EFnY0wLXCLg i love the last thumb flick at the end -lol-
I'm definately gonna look into this gear, thanks for the link - but more likely for my HPI Pro-D!!! It will match all the orange alum!! -lol-
You will have to let us know how it all goes mate, it's good to see something different to the 'norm'... what size motor are you going for? (i know it's a 2000kv - just wondering which particular one) =)
01.01.2009, 07:15 PM
Am I reading that PDF right- they will have a 50mm x 90mm BL motor? Thats gotta be about the size of a kb45 motor, only much longer. Hell, you could tow a house with something like that..
I see there other sensored motors seem to be just like Novak items, a few hvmaxx look alikes too which is interesting for obvious reasons, just a shame the kv ratings dont go below 3000kv on those ones. Are there any images of the motor you will be using (either kv version)?
Nitro?? BL rulezzz
01.02.2009, 04:31 AM
The motor i'm going to use is this one, only 2000kv instead of 1000kv.
Look at page 5 , and ten # BLS-5090
That is the one you mean....
I'm not 100% sure if the 2000kv motor had too those measurements, but one thing is for sure, it's a powerfull motor!!!
Yeah, the servo's are top quality and very fast, the 20kg servo is 0.15sec. :)
Greetz,
Joram
01.02.2009, 05:23 AM
i am going to assume it has the same measurements and that it's gonna be the 50mm diameter/90mm long can, as the name stays the same... i noticed all of their motors are named according to diameter size first, followed by the length - (BLS-5090) which is a great way to do it imo =)
Do you know what bolt pattern it has? If it's a 50mm can, i can only assume you will need some sort of adaptor to mount her up... and if it's 90 mm long - i'm not sure you will have the room... have you checked the length? i think from memory there is only room for a can 80mm in length? correct me if i'm wrong tho!!
Nitro?? BL rulezzz
01.02.2009, 05:39 AM
It will fit, there is exactly 90mm room.
Well for the adapter, thought you had one too, isn't it?
Greetz,
Joram
01.02.2009, 06:15 AM
ahh - my bad - i thought it was 80 hehehe =)
Yes, i have an adaptor that Mike made up for me, but my motor is not quite so large, at only 44mm diameter (vs 50mm), and with 30mm hole circle... it will depend on the hole circle of the 5090 (i called it bolt pattern before - either or :))
http://www.lehner-motoren.de/ms22_mas.php
Maybe email them to check , and if you have any dramas, get the specs and i'm sure Mike can make it up for you =)
btw - the adaptor is 44mm diameter with the 30mm hole circle, so you may need a 50mm diameter adaptor with XXmm hole circle :)
