George16
Supermaxx
George16's Avatar
01.05.2009, 05:52 AM
Welcome to the forum.
What emaxx do you have? I have a gmaxx with a 1515 1Y 2200Kv running on a pair of 3S 5000mah for a total of 6S. The speeds are insane. This is basically my speed truck.
ANy enerland-based lipos such as Neu, Flightpower, Polyquest just to name a few are the best packs out there. Then are are also cheap lipos which are getting good reviews such as Zippy and Rhino.
If you run 2 5S lipos in series, it will become 10S which will smoke your ESC. You want to run it in parallel to increase mah(runtime) while keeping it at 5S. I use a pair of packs to balance the weight on both sides of my truck.
There are different good chargers out there such as Astro, Hyperion. I'm using a Hyperion Duo which charges a pair of batteries at the same time. No, you don't need a discharger.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
