jhautz
jhautz's Avatar
01.07.2009, 06:55 PM
What size is the inside diameter of the bearing for the center dif?
Just wondering if finding a different bearing with a normal 16mm outside diameter and an inside diameter that fits the diff would be an option to making a standard Kyosho dif work. Do you know if the chassis mount hold for the center dif/motor mount would line up with the chassis holes or is that different too?
to make it...
or break it...
Silent...But Deadly
