Kyosho D series 4wd Center Differntial - Motor Mount - Bearing ? Ideas
bensf
01.08.2009, 04:06 AM
You should be fine cutting aluminum as long as the bit is steel. (Preferably hardened) You won't be using it for that long and it will make a nice cut then what you could do with your dremel. IMO
bensf
Off
