himalaya
himalaya's Avatar
01.10.2009, 01:24 PM
I agree. I have about a bazillion Deans and not about to switch now, lol.
Soldering even 10GA cleanly is indeed possible if you are skilled enough. Not ideal, but possible. I do agree on the grip area of a Deans is too small, but really only on the male plug, but I found a way around that.
No need(maybe impossible) for a grip area, just hold the wires and pull them apart, for 12AWG wires with good solder quality, that's just no problem.
TRX connector is obviously a much newer design, has no reason to be worse then the old one. Deans does require higher soldering skill, heating over several seconds will destroy the plastic, making plug/unplug even harder.
....What a Blue Sky....
