danhfvcsd
01.14.2009, 02:08 AM
Well - all the wiring is pretty much done... i just have to add 'power' plugs to the esc, and also the batteries when they get here... oh - and i have to get the rx wire mounted =)
Didn't end up covering the wires like i wanted to - but they are placed well enough now that i don't need to worry too much about hiding them =)
Overview...
Up front - i shortened just about all of the wires with new servo connectors instead of soldering anything... sorry bout the flash - photography skills lacking =)
These plugs are double sided taped to the tranny case...
*the upper goes from ESC to BEC...
*the lower goes from BEC to Battery output wires on ESC...
Everything then runs under the motor...
...and then under the esc and as hard as i tried not to - i had to use one zip tie here hehehe...
Wiring in the rear is pretty much non-existant from above with the exception of the motor and power wires =)
c'moooonnn aussie dollar, rise baby riiiiseee!!!!!! :D
