starscream
RC-Monster TQ
starscream's Avatar
01.16.2009, 05:45 AM
RC Monster sells a "Front Motor Cover or brake spacer". Select the brake spacer from the drop down.
This is the best solution for this issue.
Another way is to use a motor with a lower kv so you can run a bigger pinion. If you don't have another motor, then the $10 brake spacer is the way to go.
Ha Ha
