01.18.2009, 03:11 PM
1. Depends really on whether the vehcile has a trans or diff to start with. With a center diff, you can tune the car more so that it doesnt wheelie like crazy- better cornering too. Beyond that, there is the obvious weight saving, lower CoG usually, and you have fewer gears to worry about grinding compared to with a tranny.
2. Depends on how much room you have for cells to start with. Typically, you will see a 4s lipo setup using a ~2000kv motor, and a 6s lipo setup using a ~1600kv motor (assuming this is for racing rather than bashing really). The castle 2650kv motor is great for 4s lipo, but with a kv that high you wouldnt run higher voltage, but would run lower gearing perhaps (Im not the greatest expert on buggies and truggies).
3. Series harness- see BrianG's website for diagrams: Clicky
01.18.2009, 03:42 PM
gas can't freeze
-direct to diff conversions have no flexibility in gearing and shouldn't be considered unless you understand all of brushless r/c's parameters
- we can't say until we know you're spur/pinion and diff gearing, kv of your motor, tire size and desired top speed
-BrianG's website http://www.scriptasylum.com/rc_speed/_wiring.html located in sticky in the brushless section titled, "speed calculator"
you should read the stickies in the brushless section and any faq's and you will be well on your way
