CRAP!!!!!!!!!i can't apply a very low trottle,,,a big cogging appear at mid trottle and my motor come really hot!!!!!!!i try every setting as possible ans nothing to do....not smooth like a mmm... o yes....
my set-up e-maxx geared 24/62,1515 1500kv 6 cell lipo
That is curious because we had similar issues trying to run an outrunner off that same esc. We actually fried the outrunner. It was working fine on another esc and then on that one smoke.
i just hope that we are the only guy's who have this issue....so i shipped the bad unit today for a replacement.....but my friend had one(150amp)and it un flawlesslyso i put it back a mmm in my truck
e-mike, I found your MMM has motor wires soldered directly to the board, does it come that way or you mod it?
Mine has battery wires soldered and femail bullets for motor.
what pwm-setting did you try? i experienced that w. a higher pwm coggin disappears, just like timing. first put the pwm higher, then try different timings, I use eg. 7deg. for a two pole, as long temp. is ok. The cables/wires aren't too long?
what I've read about the small ezruns it seems that at least these esc's are quite ok.
I dunno if that helps, just a try.
I like the three big 1000er caps, that looks solid. size DOES matter...
have you tried a 2 pole motor yet ill assume you used a 4 pole when you had the problem
i try a lot of thing,,3 or 4 cell lipo,other motor(feigao and a 1515 2,5d),,ive played with the timing,change the receiver and the transmetter,so nothing to do the esc cog at mid trottle and mu motor come hot really fast
did you take off the green ring of the esc that come around the receiver plug of the esc??
donīt do it...
this ring is like a magnet to prevent magnetic interferences on the car...
brushless motors produces alot of magnetic field and mine 150a hobbywing was doing that until i put that green ring with the wire around it again..
