so it finally snows, and i rebuild my emaxx w hv esc w/6.5 motor. when i reprogram the esc, it thinks full finger pull is full reverse. when i flip the throttle channel and reprogram, same results full finger pull is full reverse. i then set it up so, reverse was 25% and i cant seem to get forward movement with a finger pull. if i flip the throttle channel after the program the truck moves and with throttle trim i cant get it to stop
arggggh
any ideas i know this has worked before this is my old setup
also hyperion eos0610i users, what charge cycle do you use and why linear normal automatic?
thanks
