Dagger is right, but there are other limitations as well.
Don't confuse PWM frequency with commutation frequency, they are asynchronous.
We have successfully run 14 pole motors over 60,000 RPM on the MMM software without significant timing changes, and the MOSFET switching times on the MMM are in the order of 70ns -- so there will be NO ISSUE running higher pole count motors on the MMM.
The MMM uses a very high processing power microprocessor (25 MIPS) -- more than 4 times faster than competing ESCs. We also have the fastest timing calculations and loops in the industry -- often faster than competitors by an order of magnitude or more.
So the MMM will run high pole count motors better than anything else on the market. And it will keep timing tighter and efficiency higher than any other ESC, especially at high RPMs and power levels.
Patrick
That's nice to know Patrick. Too bad my Big Maxx didn't like the MMM though, bad commutation according to Plettenberg.
