Ryu James
Ryu James's Avatar
01.20.2009, 12:54 AM
Originally Posted by slimthelineman View Post
Ryu- nope just used a little flux on the wires from the motor and pre-tinned the 10awg. to the esc, toched the ends together applied some heat and BAM! we got a connection. due to the type of wires used in the windings (soft drawn copper) bending is a no no. they WILL break if you bend them back and forth alot. the way i did it allows me to service the motor or remove it or whatever without having to ever bend the wires.
thanks for the compliment, i like clean cars and it took some thought to get my layout the way i like it, but it works great and is ballanced pretty well as long as my batts. are around 500g.
so you didnt twist the wire together or anything? just butted the two ends of tinned wire together and that has held fine?
Jammin SCRT10 Neu 1512 1y
