01.20.2009, 11:50 AM
Not true - Linc is correct - You just need to sync the motors and esc.
I believe you mount the motors to the spur with pinions attached but not tightened. Then use a 1.5v battery accross two phases to align the motors - Only the shaft should rotate as pinion locked agains spur.
Then tighten the pinions down.
