01.23.2009, 12:02 AM
Hey kids! I have owned all of the mentioned motors...
Lehner 1930 = 36mm dia X 54mm long
Medusa 36-60 = 36mm dia X 60mm long
Neu 1509 = 39mm dia X 54mm long
So you need a motor that is somewhere in those specs. Nothing against a lehner, but a hacker c50 motor will be just as good. They are a bit large in diameter, but a L can should do what you want (based on what lehner you are looking for)
Some other info about your desired results and setup would be cool.
As for the race that TD saw. Give me either vehicle and I will make it faster than the other. Setup and driver skill are about 60-80% of the total. Plus battery choice will make a big difference.
