Hardstyle
Hardstyle's Avatar
01.23.2009, 08:17 AM
Omg the dang thing burst into flames and got hit by a tractor
Juuust kidding!
Powering first time the system had some difficulties. Fan keeped blowing, Leds were all on and no response throttle nor steering. Figured that I didn't Bind my receiver with the radio after making a new profile for it. So it didn't get signal.
Did a little test run outside. It runs very well, can't really say about the performance yet, traction isn't best at ice/snow. Front wheel flyed off though..
Throttle is smooth as a butter, a light year ahead from my bk controller. Temps were quite normal for this weather motor 30C° controller 35-40C° outside 0C°. Batterys were... cold
And another thing. I was suprised that 14t mod 1 pinion was too small. It barely touched the spurs teeths.. So had to settle for 16t.
I tweaked Esc's settings a little. Should I change something?And about the brake amount, is it all the same if I tune it from the radio or from the esc's setting?
Name:	MMM Setup.jpg
