E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.25.2009, 12:56 PM
The freezing temps won't hurt it as much as the radical temp changes that create condensation and the moisture it the garage that will eventually corrode connections external connections as well as connections on the circuit board. However the most damage is being done by not cleaning ur truck after using it! If mine is dirty I take the motor and esc off and hose it down, dry it off and put a light coating of wd-40 on the truck. After running in the snow I stand it against the wall on the front bumper so that it all melts and runs away from the esc they a coating of wd-40. A clean truck is a happy truck! Bearings last longer as do u-joints, cvds, and motor. Dirt creates more friction and a heavier truck putting more stress on everything!
