E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.25.2009, 07:05 PM
are your hinge pins straight? Sounds to me like there's another issue causing this. If your breaking around the pin then all that stress is most likely coming from the suspension arms. Do you have the pins in the upper or lower roll center holes? Try the lowers if they aren't already there. Bent pins would cause added stress if your re-using bent ones. Do you have the right suspension pushrods for your setup? There are different rods for p1/p2/p3 rockers.
