Here's my latest update
I'll try and get the vids asap, but with the weather here it might be hard to get good ones for a bit.
So here is the batt I'm running ... it's the zippy H 5000mah 4s 20-30c
Here is the castle combo as it comes from the factory
Here is everything mounted up, obviously I took this pic AFTER the test run. It has the tekno dual shank pinion on right now beacause my loctite didn't hold and the RCM pinion went flying :D
And here is the clearence for my batt, with the tray mounted more forward and outward with the 62T spur gear on atm. I just changed it to the 52T ofna hyper st pro truggy center diff which leaves a lot more room for the batt..
I'll get vids up asap, but I have already converted my 2 RC buds at work to brushless after seeing this thing go today so my next build will be converting my buds revo...
