AP Alex
AP Alex's Avatar
01.26.2009, 10:17 AM
My father is an old electrician and said it could be a cold soldier joint. He has a meter that I can check it with. I will beat this thing. I will post pics of the project when I'm finished.
01.26.2009, 01:35 PM
Most likely a meter will not show a bad solder joint unless it is REALLY bad. Any resistance you see will probably be just the meter leads. Resistances that low are better measured with a conductance meter TBH.
t-mange
t-mange's Avatar
01.26.2009, 03:28 PM
Check the bullets, i got i cold solder joint in my mmm package NIB.
Hyper 8.5 Pro w/ MMM, 5s rhino, MedUsa 36-70-1600
Thunder Tiger zt w/ Sidewinder 8000kv kombo and 1300Mah 3s
AP Alex
AP Alex's Avatar
01.26.2009, 03:57 PM
How did you catch the problem? Were you having similar issues?
Thanks,
Alex
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
01.26.2009, 01:11 PM
I'm sorry for being vague, but when I said check ALL the connections I thought solder joints were included... I hope it's that simple!
Hardstyle
Hardstyle's Avatar
01.26.2009, 01:34 PM
This is kinda far-fetched but try twisting the wires at the sametime when running the system. I had similar problem with my bk controller. Found that parallel wire were badly soldered. It just cutted the powers when twisting at the right place..
01.26.2009, 04:18 PM
Apply some "force" to the bullets and wire - should not crack/break...
Now within about 20 mins patricks going to be asking to QA stickers to bust someones balls... :)
t-mange
t-mange's Avatar
01.26.2009, 04:48 PM
Na, i plugged all the wires in to the MMM, and then I was going to yank them all out off the mamba(for a photo) when the wire came out, but the bullet didnīt, so i resoldered them all, just to be safe.
It never made it to the buggy before this, but i have had a friend with the same problem you described, so I resoldered all off his connectors between the ESC and motor and the problem was gone. So itīs definitely a case off only 2 out off three phases fireing.
AP Alex
AP Alex's Avatar
01.26.2009, 06:34 PM
I just home from school and dad meet me at the house with his meter and sure enough one of the wires would not carry a tone across. Resoldered that wire and everything worked like a champ. The just got home from school sounds funny. I'm the assistant principal of a local high school.
Thanks
Alex
01.26.2009, 06:39 PM
Did the meter show any resistance? Just curious.
AP Alex
AP Alex's Avatar
01.26.2009, 09:08 PM
The setting that gave the tone read .011 for all the other wires and read .014 for this wire when I fixed it. He had another setting that he turned it to and all the good wires read 0 and this will still had some readin, but I did not pay attention to what. It was some sort of 70 series meter. He was an electrician/telephone man. The meter was used by him when he was a telephone repair man/ equipment installer. I'm sorry I did not pay closer attention. I was just happry I was not out a lot of money.
01.26.2009, 09:37 PM
Congratulations on fixing your issue.
What's_nitro?
01.26.2009, 11:35 PM
Awesome. You know what this means.... Wheeeeelie time!!!
