Matt, increasing the spur gear tooth count while using the same pinion will increased your low end torque but decrease your top speed. You need to use a smaller spur or bigger pinion to increase your top speed.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
