12.14.2008, 11:54 PM
I do, I'm just lazy.
MetalMan
MetalMan's Avatar
12.15.2008, 12:55 AM
Originally Posted by BL_maxx View Post
nice work man. are those actual beadlocks?
They're half beadlocks, where the outer bead is locked, but the inner bead is glued. The only downfall of this truck IMO.
12.16.2008, 09:58 PM
That makes no sense.
MetalMan
MetalMan's Avatar
12.17.2008, 12:57 AM
Exactly.
chip cross
01.29.2009, 07:08 PM
Machine work is done !!!
brushlessboy16
brushlessboy16's Avatar
01.29.2009, 08:09 PM
WOW!
that looks amazing!
did you do the machinework yourself?
01.29.2009, 10:28 PM
Beautiful! I'd even go so far as to say, "Godly."
jnev
jnev's Avatar
01.29.2009, 10:51 PM
Amazing work right there. Just awesome! Enjoy the truck!
chip cross
01.30.2009, 01:06 PM
WOW!
that looks amazing!
Thanks guys the motor was moved .100 to the passanger side so that the battery would fit properly.
Takedown
WARNING: May become violent.
Takedown's Avatar
01.30.2009, 01:16 PM
Looks great chip. Were did you get the custom parts machined?
RIP- Tammy (9/14/08)
chip cross
01.30.2009, 01:27 PM
A vendor on Rccrawler.com
Hey Chip, I like most of the work, looks a bit heavy but I am sure it will be sturdy. You may have to beef up your display shelf a bit...
Anyways, If you plan to run the truck, cut that hoop off that closely matches the spur gear. If you get a rock caught in there I can pretty much gaurantee that the esc will cook from over current as the motor instantly locks up. That happened to me with a buggy I had with a metal spur on it, and I have always run plastic spurs since. Cheaper to replace a 5 dollar spur than a 150 dollar esc.
chip cross
02.07.2009, 12:28 PM
It is suprisingly lite for the total set up which I like a lot, when you add the battery it gets heavy but what do you expect. I really didn't care for the spur cover that was a miscommunication.
chip cross
02.15.2009, 12:32 AM
Just a little bench top test.
phatmonk
RC carbon junkie
phatmonk's Avatar
02.15.2009, 02:27 PM
Dude thats freakin sweet nice work.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
