Hardstyle
Hardstyle's Avatar
01.31.2009, 06:43 PM
Very clever esc mount . I think it will be fine on there. But if using lower body, might be a problem.
I see that there is a little room for a L-bracket at the left side of the motor plate. Couple holes to it and you might get it there and mount the esc.
ssspconcepts
ssspconcepts's Avatar
01.31.2009, 07:56 PM
Yep...it is a tight fit any way you go. As it is, the motor wires just barely touch the under side of the body. Next time I am out and about, I am going to pick up some aluminum and try fabricating something for the motor mount.
