George16
Supermaxx
George16's Avatar
02.03.2009, 08:16 AM
Originally Posted by Duster_360 View Post
The 16.8v diffs from the 3906 are stronger than what you just destroyed. I'm running a set unshimmed in my 3905 and they are better tha the stock diffs. They are an intermediate strength solution to this problem. The FLM hybrids are prob the best all around solution, but are pricey and need to be shimmed as pointed out. Go to Ebay and find the diffs for use in them, you can get them for about 1/2 as much than elsewhere.
Using buggy diffs will re-gear your EMaxx so be prepared to make a spur/pinion gear change to compensate.
You're not making sense at all. Are you saying that the 16.8V diffs from a 3906 are stronger? The 3906 uses the weak 2-screw diffs while the 16.8V(3905 emaxx) uses the stronger diffs.
He said he already destroyed his 3905 diffs.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
