Emaxx_Quebec
Emaxx_Quebec's Avatar
02.03.2009, 11:17 AM
What is the best to use to be closest to stock maxx diff
  1. Raminator
  2. Aftershock
  3. LST
  4. LST2
  5. Mayhem
What the gear ratio of those diffs?
Thanks
02.03.2009, 12:08 PM
  1. Raminator
  2. Aftershock
  3. LST
  4. LST2
  5. Mayhem
Thanks
1st 4 you listed are all the same, 13/43 ratio. Not sure about the mayhem.
Emaxx_Quebec
02.03.2009, 12:13 PM
Thanks
So the only diference is the case. ( plastic vs silver alu vs blue alu)
Emaxx_Quebec
02.08.2009, 01:01 PM
question about the lst 2 diff convertion
do my traxxas driveshaft and center cvd can be use whit this convertion
a got a 3905 maxx
You'll need to purchase the adapters mike sells, here
. those will go in place of the normal outputs for the left and right. so if you replace both diffs you'll need 4 of those units.
So Ok for the 4 corners.
BUT for the center??
I use
Can I bore ( drill) them out to 8mm.
Or do I need something else like 2 of
If so, how do i connect them to the CVD.
Thanks.
SnoopMaxx
SnoopMaxx's Avatar
02.09.2009, 01:44 PM
You need a set of these 1/8 diff output shaft
Use these 6mm output shafts to replace the stock output shaft/drive cup on most 1/8 diffs. Allows use of stock driveshafts for Maxx and Revo trucks while using 1/8 diffs. 2 required per differential.
You can also make them from Revo spindles
Morten SnoopMaxx
Never to old to play
c",)
Emaxx_Quebec
02.09.2009, 02:33 PM
Yes, i know but my Q is for the center shaft.
The one that goes from 8mm diff pinion output to trans.
