glassdoctor
TEAM FUSION
glassdoctor's Avatar
02.04.2009, 04:31 AM
The RC8 needs a pinion 3-4 teeth higher than most buggies because the f/r diffs are 43/10 instead of the more common 43/13.
Your 44/16 is about the same as running 44/12 in a car with 43/13 diffs.
Funny thing is, I think you should have no trouble running with the nitros @ 44/16... should be running like 45mph
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
