02.06.2009, 02:26 AM
Originally Posted by hemiblas View Post
From what I can tell the 5000mah cells hold up better than the 4000mah cells in general, but ya even for the same C rating you get more amps. I just ordered a 5000mah 25C and if the specs are right it should be more than enough. 125A continuous is a lot and bursts of 175A is just crazy.
Unless you do something like gear it way to high it should work just fine and those batts should be more than enough. When I get mine I will post how it runs. I plan on using it in 5S config with a 3S zippy and a 2S truerc 8000mah 15C lipo and MMM 2200 combo.
Go ahead and experiment, that way when you kill the flightmax lipos you can send them to me and I ccna examine them. That will be mush cheaper than me buying my own to look at. Thanks for thinking of me!
If I were you I would not do that. Mixing lipos is bad, Mm-Kay.
