monsterbaja
monsterbaja's Avatar
02.08.2009, 03:32 AM
Anyone know if i can do that with the DX3 R/s
02.08.2009, 03:39 AM
Originally Posted by MetalMan View Post
Some radios can be set up such that the PiStix isn't necessary, by moving the throttle trims all the way negative. This worked with my React (used a HV-110 without PiStix) but it won't work with all radios.
The HV-110 is a great ESC for sure! Super smooth starts are very welcoming considering it is an airplane ESC.
Yeah, I guess I should have mentioned that.
Yes you can. I used a DX3.0 and a DX3r and was able to get it to work on both. It worked after fiddling with trims/EPAs, but IIRC there was still some issue that made me not like using it like that. So I ended up getting a PiStix adaptor and it was much easier.
02.08.2009, 03:56 AM
Not to piss in anyone's cheerios... But Lautach's 10s esc is a great alternative to the hv110 and it comes with a prog box too. Good for 100 amps. I have run air speedos with a pistix and prefer the Lutach esc, and so does your mom.
