I noted the start power was on 5 on the Hobbywing, I usually have it at lowest on the MMM so have adjusted it to that level, timing I always put a 4 pole motor at 15 degrees and a 2 pole at zero.
I have also turned off drag brakes as I have it on the MMM
would these have been responsible for such a spike in heat?
