02.08.2009, 08:08 PM
Weird. In theory the MMM should be the more powerful setup as the FETS used in that esc are lower resistance than the ones used in the MM, allowing for greater current draw.
Could it be one motor is more worn than the other of a bad connection- try swapping them over and re-comparing them to see if its motor related or not...
