The outside of the case is about the same size as a 540 motor can. It's gonna be a whole lot smaller than an emaxx or other transmision. I'm gonna put two gears the same size out the end of it so I can have the driveshaft run parallel right under the motor and planetary to the front and rear driveshafts.
