02.11.2009, 09:08 PM
Originally Posted by DwightSchrute View Post
... I don't charge them as one pack though, i hadn't thought about that...does that make a difference? can i charge it as a 6S using the series adapter? how would i balance them then? they only have 3S taps...
It's best to charge them the same as they are used - in your case, in series. Then you can use the diagram below to make an adaptor so that all the cells are balanced together:
