how will this work out? I'm guessing I will have to stretch the tire Im willing to give that a try...where can I read up on the taping of the inner tire because Im having ballooning issues now and expect this will continue...
Nice Skellyo thanks for the heads up looks as though that shouldn't be an issue for me since I have the standard ones chosen.....right?
Im such a newb when it comes to this thanks for the patients!
the J concept's rulux 1/2 up's are LPR size and will require the MT sized badland to be stretched on, you will not need to stretch the badland's onto the maximizer's, also you will not need to use CA glue with the beadlock's, they hold. TRUST ME!
flip the tire inside out, clean with rubbing alcohol and apply duct tape to the center (treaded portion) of the inside of the tire....
I think Im going to scratch the maximizer and go with this set up--
1 x Pro-Line Premium Blend CA Tire Glue (Medium, 15-20 sec)
1 x Traxxas 17mm Wheel Hubs & Nuts (Blue) (4) -
2 x Pro-Line Badlands MT Monster Truck Tire (2) -
1 x JConcepts Rulux 1/8th Truck Wheel 1/2" Offset (White) (4)
As soon as I get a thumbs up from you all on fitment..and that I have all required parts..thanks!
Looks good to me. I'd use the thin CA instead of the medium. I've found that the medium takes way too long to cure and doesn't make it down between the bead and wheel as easily.
Ill second that medium is no good at all! Use thin ca, you may get a bit on your tire, but just have a paper towel ready to wipe it off!
Will do...Im ready to order but seems silly to make 2 orders and shipped to 2 different locations...how about I send it all to you you dye them and I will paypal you the cash to cover the dye and shipping to my address and you ship it off to me....
And I assume with over 3xxx posts you can have more then a few guys vouch that your a stand up guy that wouldnt do me dirty...lol
