Originally Posted by traxxasbasher13
I guess I hadn't ever thought about the motors bullets. I looked at them and they were almost falling off. The problem is I can't get any solder to stick to the wires. I will go to my buddy's house today or tomorrow and try one of his motors to see if it still works right.
Use decent 60/40 solder and flux... And a good, hot iron. The flux cleans the wire and helps the solder stick to it. I usually skip the motor to esc bullets, as most of them will eventually cause problems. The big CC bullets work well, but the smaller ones on the mm are questionable...
