02.16.2009, 11:23 AM
Or you can send it to neu, and if it is less than 1 yr old they will fix it for free and mail it back to you. You have an APO addy, IIRC, so there should not be a problem, only time....which sucks. You could pull the rear endbell off and make sure that the rotor has not damaged the windings.
