02.16.2009, 01:32 PM
Most ESCs are set up to not do anything if it doesn't receive a signal from the receiver. So, if your Rx battery pack gets too low, you might get some erratic behavior (especially when turning which causes the voltage to dip lower momentarily) before the system just stops. It should not turn into a runaway like a nitro though.
