DickyT
02.16.2009, 02:05 PM
Originally Posted by kulangflow View Post
What are the power specs on your new XRS?
170 hp, 127 ft-lbs, very tight ratio on the 1st 5 gears with 6th more like an overdrive.
I want to mod it, but keep it mild (by my standards), intake, the trd catback (no fart cans here) and a vvtl-i controller to lower lift to 5500 and play with the air fuel ratio. Some shorter springs of similar rate and coil over sleeves or performance dampers and some light 17" wheels, rays or something of that nature.
None of that right away though.need to recoup a bit after the down payment, the coffers are a bit low right now.
