02.17.2009, 06:17 PM
I think you'll be more than happy with those packs. Dual 5s 2.5Ah is the same setup I'm running in a few vehicles, except in a single 5s2p format, and they work great.
On to your question: Not gonna happen. Even in you paralleled the 5s1p packs as a single 5s2p pack giving you the same 5Ah setting, the voltage is not the same as a a 4s pack of any capacity. Doesn't the duo have profiles you can select from? Just set one to charge your 4s PQ packs and another to charge Mike's packs.
shizzon
shizzon's Avatar
02.17.2009, 06:22 PM
[/QUOTE]Doesn't the duo have profiles you can select from? Just set one to charge your 4s PQ packs and another to charge Mike's packs.[/QUOTE]
I just received the duo and haven't really gotten to know it yet (in fact i haven't even used it as my 1515/1y is in for warranty repair at Neu), so im not sure of its capabilities and was asking those who already have and have used it. And as far as the pack charging goes i was aiming for what you said last, 1 side to charge 1 of the 2s packs and the other to charge 1 of the 5s packs at a time, not a total of 4 packs at the same time.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
Sammus
Sammus's Avatar
02.17.2009, 08:44 PM
The two channels are like two seperate chargers, even all the profiles are seperated. You can save up to 10 profiles on either side. So yes, you could have one side with your 4s packs already selected, and the othe channel with your 5s packs already selected.
