crazyjr
crazyjr's Avatar
02.18.2009, 05:27 PM
yes the 2.5d is really a 5s / 6s crazy motor - 8s it think you need to go for a lower kv...
I know how wild the motor is on 5 and 6s and yes, its an awesome motor
Originally Posted by azjc View Post
the 60,000 rpm number that Neu uses is more for the bearings, I wouldnt run a Neu beyond 45,000 IMO anything beyond that isnt producing anymore power.... lipos are 4.2v's fresh off the charger (this doesnt last long when running the motor) I would make your calculations using 3.7vpc. I run a 1515/2y with 10s in a converted Revo and very happy with my results
On 5s i'm currently running 31,000 RPM's, I was just asking if anyone had tested the theory that Neu's were not only more efficient at higher RPM's, but that they may be better run at that level. For a while there was a lot of talk about high RPM's and Neu's in the same sentances, then it died out. I was wondering if anyone had followed through on any testing
