Sammus
Sammus's Avatar
02.19.2009, 08:01 PM
Why does everyone always go on about a portable programmer? I use my Tx to make simple adjustments in the field if I have to.
Is it possible to have RPM limiting? would it be any use? maybe it could be used to run a high kv motor on high voltage.. then again, you could just buy a lower kv motor haha.
BTallack
02.20.2009, 01:49 PM
Sometimes there's things you want to change that the Tx can't do. For example say you're switching from LiPos to NiMHs and need to turn off the LiPo cutoff. This may be more useful for say the Mamba Max than the Mamba Monster, but it would still be a nice feature to have. I run both LiPos and NiMHs on my MM powered Losi XXX-S and it's a pain to have plug in to my laptop to turn off the LiPo cut off to switch to NiMHbatteries, or I have to risk running LiPos without a cut off.
A programming card similar to the ones that Losi Xcelorin systems come with would be perfect in my opinion. Simple jumper based system.
