squeeforever
squeeforever's Avatar
02.22.2009, 12:44 AM
Originally Posted by mistercrash View Post
I have read a whole bunch of stuff regarding this diff from cowboy (thanks cowboy for the file you sent by the way) and I don't get why you can't use the rear brake. All that's needed is a longer shaft with an extra hole in it for the pin of the rear brake hub. I must be missing something here.
Yea, you should be able to do that no problem. Finding a shaft long enough will be the difficult part. The Traxxas shaft with the gear cut off should be long enough.
