captain harlock
RC-Monster Captain
captain harlock's Avatar
12.05.2005, 11:58 AM
As usual, after each run and befor each run always check your machine and also stay away from Robinson pinions ( specially the enlarged bore types) and try to use some grease to smoothen the bore and the motor's shaft. Using a sand paper to clean the shaft and also the inside of the pinion. If I have any other suggestions I'll tell you immediately. Nice to see you again.
Nice to meet you!
