Pdelcast
Pdelcast's Avatar
02.24.2009, 01:36 PM
Originally Posted by jzemaxx View Post
Here is the problem with that logic. I have used these very same packs with other cheaper controllers (Turnigy 100HV) and as high as 12S and nothing has ever happend to those controllers with huge immense loads when I was doing speed runs. I also run the same exact packs on the HV110, and use to run them on the little old mamba max on 5S. NONE of those controllers have ever given me a problem and still use them on apps when the MMM dies. Now this controller has gone dead 3 times, I swap in my trusty HV110 or mamba max between service times and magically never have any problems. The only common variable being changed is the MMM. The batteries never change....
You just proved the point... The HV controllers are based on 60V processes -- the Mamba Monster is a 40V process.
If there was a problem that was causing voltage spikes during regenerative braking, the Monster could be damaged BEFORE the HV controllers.
That's why the Monster is rated to 6S and no higher. It can take bus surges to 40V.
Patrick del Castillo
President, Principle Engineer
jzemaxx
02.24.2009, 01:55 PM
What has me confused is all my race trucks are mechanical brake...reverse and brake are all but disabled.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
Pdelcast
Pdelcast's Avatar
02.24.2009, 02:09 PM
Now, that said, ANY battery that is pushed beyond its capabilities can damage an ESC.
Let me say that again:
ANY BATTERY THAT IS PUSHED BEYOND ITS CAPABILITIES CAN DAMAGE AN ESC.
AS CAN BAD CONNECTORS, BAD WIRING, AND BAD SOLDER JOINTS.
We have gotten so oblivious to the fact that we are harnessing thousands of watts in these setups -- any problems in the system can cause problems with other components in the system very quickly.
So we must be VERY careful NOT to push batteries harder than they can handle.
The very same is true of Motors -- and people seem to accept the fact that certain motors can only be pushed to a certain point before they fail.
Why do the same people not understand that a battery pushed beyond its capabilities can damage the ESC?
The ESC relies on the battery to both SOURCE high currents without significant voltage drops, and to SINK high currents without significant voltage rise. If the battery cannot hold the bus voltages within a reasonable voltage, then the setup is PUSHING THE BATTERY TOO HARD.
A battery needs to have the ability to sink braking energy during hard braking, and take that energy back as charge energy. If the battery can't take the energy back quick enough, the voltage on the bus will rise, and eventually it could get high enough to damage the ESC. We do bus voltage monitoring on the Mamba Monster, but if the battery is REALLY bad, the voltage can rise faster than the MMM can respond to it.
It all comes down to this: Don't push any parts in your system beyond what they can REALISTICALLY take. This includes motors, batteries and the ESC.
Just as some motors are better than others, some batteries are better than others. You can't expect a $25.00 Chinese motor and a $250.00 Neu motor to perform on the same level. Same goes for Lipos. There are applications where cheap lipos and cheap motors WORK JUST FINE -- but there are other applications where they may perform below par.
Patrick
Pdelcast
Pdelcast's Avatar
02.24.2009, 02:11 PM
LOL, 5 new posts while I was composing that post....
