roll cage ?
emaxxfan
roll cage ? - 02.21.2009, 09:33 PM
Will a roll cage for a new t-maxx 2.5, 3.3 fit an e-maxx 3905?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.21.2009, 10:29 PM
Doubtful! T-Maxx uses an aluminum plate for a chassis, just a flat piece with a couple kicks on the edges for strength. The chassis are nothing alike!
squeeforever
squeeforever's Avatar
02.22.2009, 02:08 PM
Being that alot of the cages mount on the towers, its quite possible that it will fit. It just depends on the cage. Some will, some won't.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.22.2009, 02:16 PM
Only the new bigger 3.3 has an equal wheelbase, so that would be your only chance at a cage that would bolt up to the towers
squeeforever
02.22.2009, 07:45 PM
Um....They've all had equal wheelbases...
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.22.2009, 08:04 PM
U may want to research that, I already did. Original e/t-maxx, 2.5, and 2.5R have a 12" wheelbase. The new 3.3 with the big tires and the 3905 have a 13.2" wheelbase
squeeforever
02.22.2009, 08:16 PM
I see what you were saying now. I thought you meant the all the old Ts and Es where different. I misunderstood what you were referring to when you said only the 3.3 has a equal wheelbases.
emaxxfan
02.23.2009, 01:00 AM
Thanks guys. The cage I'm looking at actually bolts up to the bulk heads I think.
JavaBlack
02.23.2009, 02:20 PM
There is an Rc-Solutions roll cage. I have been using mine for a while now and everything had held up pretty well. The cage will take plenty of abuse but i have to say the only down side is that sometimes it can be a pain to get an alen key or screw drive into certin spots.
emaxxfan
02.23.2009, 10:10 PM
Ya, the rc solutions cages are awesome but a little more than I can afford at the moment.
Andrew32
02.24.2009, 07:36 PM
hey sorry to play the devils advocate
i ran a cage but it SUCKED. After a while it was all bent up and crappy. I would recommend u get a proline body or any other body with a .062 or thicker body.
