02.24.2009, 08:29 PM
Mike makes a bolt on front cover, and I highly recommend it. The threaded holes in the can are not that deep, and I have seen them strip out. The cover bolts on and has its own threaded holes, so if you strip them you just replace the cover. I also think Mike is working on a rear cover. I will just use some al tape to cover those holes. A clamp is also a good idea, as the rear endbell is just pressed on.
