newbie tekno-rc revo owner... -
02.18.2009, 08:56 PM
hello...i just finished my tekno-rc revo conversion (mamba max + Feigao 540XL - 9XL Brushless Motor (9trn, 5mm shaft, 74A, 1853kv) i only use 7.4 lipo battery on it. is that the reason why it runs very weak? or maybe the electi-clutch was the problem, totally confused  ...i will try to use direct drive to see if it will run better. still waiting for the parts from impakt RC. here's what i have ordered...
1 x Novak Pinion Gear (Mod 1, hardened steel, 5mm, 15t) (NOV5104)
1 x RC-Monster Electric Motor Mount (CNC aluminum, Traxxas Revo) (RCM-MM-REVO)
1 x *Tekno RC Long Shank Pinion (hardened steel, Mod 1, 5mm bore, 15t) (TKR4155)
can anyone tell me if this will help...thanks a lot
02.18.2009, 09:37 PM
Yes, you need more juice - that set up should be run on 4S. Is there a reason you tried it with just one battery? Also, why did you order two 15T pinions? Also, how did you mount the motor, seeing that you have a motor mount on order?
02.18.2009, 10:31 PM
I'm running the same set up but diff motor, also using a 15t clutch bell on the Tekno kit, unless u have the wide gear set, it will feel very pedestrian even in 2nd gear at full throttle.
02.19.2009, 01:01 AM
actually, i just use that battery to test it...(that's my b44's). i ordered 2 pinions, just in case one did not work...also the motor mount for the same reason...anyway, i am buying a 3s, you think it's good enough??? here's some pics...
02.19.2009, 01:38 AM
No. Your gonna need at LEAST 4S. I'd go 5S.
02.19.2009, 01:55 AM
Squee is back...WTF!
Anyways a 9xl is going to need 4s... Or pick a motor with higher kv for 3s. 4s will be better.
02.19.2009, 02:46 AM
Hoping to get my mod position or something?
But yea, if you really wanna run 3S, best bet would be something like a 7XL. I'd go 7 or 8XL on 4S or 9XL on 5S.
02.19.2009, 09:47 AM
Those pinions are exactly the same, so if you can, you should maybe change the order to get one that has a different pitch (maybe a 14T).
02.19.2009, 10:08 AM
so, that means i need to use bec...i know mamba max can only handle 3s max, right...
02.19.2009, 10:10 AM
i ordered one with long shank and the other with standard...
02.19.2009, 02:56 PM
Yes on 4s, you will need a cc bec or similar switching regulator....Just don't forget to remove the red wire from the esc plug! You may also want to add a cap as well...like this one ... http://www.rc-monster.com/proddetail...=35vcap&cat=21
02.24.2009, 10:06 PM
Is there a particular brand of lipo batt. you guys can recommend??? I planning to buy one, like what you said, at least 5s. I'm checking out maxamps (30C Lipo 6500 5S2P 18.5V) or polyquest (PolyQuest 5s 6000mah 25c)... Is there any difference?
02.24.2009, 10:18 PM
I would only use the onboard BEC for 2s lipo
03.01.2009, 03:01 PM
i have mmm esc with 5s...is it ok to use "auto" on voltage cutoff setup???
03.01.2009, 03:17 PM
Most of us here use custom selection and run anywhere from 3.1v/cell to 3.3 v/cell. I run 3.2 v/cell as a little insurance
