problem is that this charger only charges to 2.0A max
alangsam
problem is that this charger only charges to 2.0A max - 02.26.2009, 05:21 PM
Originally Posted by vbxt View Post
I think that this charger from Hobby City might do what you are talking about.
http://www.hobbycity.com/hobbycity/s...Charge_Capable
I have one, and it appears to charge each cell (up to 4) independently. There are 4 LEDs that indicate the charge status, and they switch from red to green at the end of the charge cycle at different times as each cell is fully charged.
I have no complaints about this charger other that the slow charge rates.
edit: I just remembered that this charger also does not seem to have any problems with over-discharged packs. I was discharging a SMC 5000 mah 2S Lipo with a light bulb and forgot about it. It was reading 0.0 volts on my multimeter. I hooked it up to this charger, it fully charged it, and it still works perfectly to this day. It may all be in my head, but I think that it works better than before!
Cool charger functions but wont work if you have a pair of 3S batteries and its going to take a LONG time to charge at 2amps max.
