Originally Posted by lincpimp
Hey Brian, you have the incorrect ratio listed for the savage trans...
Well it is not correct for the X model...
The output gear is 29t, p/n 86098
And the gear that drives the output gear, on the center shaft is 32t, p/n 86084
So that ratio is 32/29, so 0.90625
You have 30/31 listed for the secondary reduction (which is actually not a reduction in the x tranny)
Now the 1st and 2nd ratios look to be correct, but I checked anyways.
Input gear cluster, p/n 86097, is listed as 18-23t. The 1st and 2nd gear "spurs", p/n 76914 & 76924, are 44t and 39t repectively. So that looks good.
So 1st is 18/44 and 32/29 so 2.444 x .906 = 2.214
2nd is 23/39 and 32/29 so 1.695 x .906 = 1.535
Those figures are rounded, and I know your program does not round the same. But you get the idea.
Are the figures you listed for the original savage 25 tranny? I will have to pull up a manual to see...
Just checked the savage 21 manual and it is identical, save for a different number for the 39t gear... Same ratios though
Arrg! All those numbers. Let me paraphrase:
The savage X tranny has a 29T output gear on an 32T idler for a 0.90625:1 ratio. Then, there is no 30/31 gear set in the savage X. But, the first/second gear cluster is correct. Is this right?
As far as the flux goes, what is the correct ratio? There are a couple threads and I don't feel like comparing them to get the right gear tooth counts. I saw the scan someone posted, but it really doesn't tell me anything.
And for the 3-speed savage tranny, post the gears and I'll do my best.
