E-Revo 3.3 conversion/build
Oday9513
E-Revo 3.3 conversion/build - 03.02.2009, 08:48 PM
Hi guys, I got my first big 4x4 truck in a trade not to long ago. I got a revo 3.3 and im going to convert it. I will be using a MMM with a medusa 36-70 on a zippy 5s 5000 lipo. My mom ordered the lipo last night for my birthday present(perps to bring 13-14, get presents!) With my birthday money I plan to buy the motor and the RCM mount if I have enough money then the MMM. This should be a beast! This is my first conversion so I need some help guys. All input accepted! here are some pics...
this s an ESC plate I made for the MMM, its made out of 1/4in lexan
Oday9513
03.02.2009, 08:49 PM
wow those pics got screwed up!sorry for that guys
03.02.2009, 08:58 PM
Host them on photobucket and resize to 800x640.
Anyways, which kv medusa did you buy, as that will determine the correct gearing and voltage you should use.
if you plan to stick with the stock tranny, then Mike (our Lord & Master) sells all you need pretty much to convert the nitro chassi over to electric (motor mount, battery tray etc) then its just a case of deciding whether you want to lock it into 2nd gear and use motor braking via the esc, or keep it 2 speed and use mech brakes.
Plenty of tutorials and info to show you whats needed either way- welcome to RCM.
Oday9513
03.02.2009, 09:06 PM
Thanks! Im going to use the 2000kv one I think and im sticking with the stock trans and using the ESC brakes. Im going to buy the RCM motor mount but i think I will make a battery tray, being 13(14 in 2 weeks) i need to save all the money I can to finish the project. lol
03.02.2009, 09:28 PM
I am in the process of converting a 3.3 as well. What has been said to me many times is that the stock diffs will not hold up long to 5s power, which is what I will be running. Hence, Mike sells hybrid cases which work w/1/8 gears. They are not cheap, but, on 5s I would seriously consider them. If not the hybrid cases, at least AL inner and outer cases w/hardened gears which will reduce flex a lot.
Welcome to the madness!
Oday9513
03.02.2009, 09:40 PM
haha, thanks. I have been told the diffs will hold up, I have been told they wont...I guess I will just have to find out when my 5s and electronics comeI will look into aluminum gears and cases but nothing right now, maybe in a month or two though.
Oday9513
03.02.2009, 09:41 PM
magman what motor and esc are you going to be using?
03.02.2009, 09:56 PM
Medusa 70 series 1600kv and a mmm esc. I don't need it to go 50, just be an efficient set up
Oday9513
03.02.2009, 09:59 PM
sweet, im doing the medusa 70series 2000kv on the MMM and 5s lipo. mine will be fasterj/k...according to the speed calculator, I will hit 46mph geared 15/40 and geared 20/40 hit 53, thats fine if not to much for me.
Oday9513
03.02.2009, 10:08 PM
I see your in MA. are you going to the RCM bash this year? Im gonna try and get my mom to take me, if I can we will have to race. lol
jzemaxx
03.02.2009, 11:12 PM
I'm doing a Revo right now as well. Almost done. Running twin 4S's in parallel. My buddy's conversion runs just fine with the stock diff.
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
George16
Supermaxx
George16's Avatar
03.03.2009, 03:53 AM
I have a revo conversion running on 5s with the MMM and Medusa or Neu 1515 1Y. The stock diffs are holding out real well. It all depends on how the diffs are shimmed and how you drive.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Oday9513
03.03.2009, 07:46 AM
ok cool. thanks, so hopefully I wont have to dump a crap load of cash into the hybrid ones...
Oday9513
03.03.2009, 04:25 PM
being 13 I dont have a lot of cash. You guys think I could use like a nemisis or fiego 7-8xl? I want to get the truck running more than I care about the most high quality stuff
03.03.2009, 06:13 PM
If you are looking at a 8xl, save a little more and get a Medusa. HUGE difference in quality.
Tags
brushless 3.3, feigao motor, mamba monster max, revo, stupid converstion, zippy lipo
