03.05.2009, 04:09 PM
Originally Posted by squeeforever
Correct...For the most part. If I'm not mistaken, that support bar is now in the newer model 3.3 as well as the E-Revo, Slayer, and the T-Maxx 3.3 and E-Maxx 3905.
They pretty much all have it now I believe, but the original 2.5R and the old 3.3 didn't.
I was looking at the exploded views on the Traxxas site earlier, and those dont show up on the 3.3 exploded views. If they are holding up better, not sure why one couldnt use them. I do have to say that since I went to the AL cups, I havent had any prob's with mine.
REVO madman!
03.05.2009, 04:53 PM
AFAIK the 5308 REVO does not use the support bar, it is only stock on the electric model's....
03.05.2009, 05:05 PM
Originally Posted by BrianG
What part of the diff is breaking?
If it's the ring/pinion; proper shimming should help. And make sure the diff cases aren't deformed.
If it's the inside of the diffs, a metal cup should help. They only use two spider gears, so that will tend to flex the stock diff cup more under heavy acceleration.
i run new new diff(tougher version)this is the ring gear/pinion who ''strip''after 5 pack....so where a can shim that????
03.05.2009, 05:22 PM
Shimming the diffs involves two sections:
- between the bearings and the diff on each of the outdrives. This moves the pinion closer or further away from the ring gear.
- between the pinion and the pinion bearings. This pushes the pinion closer to the diff cup.
If either of these are off far enough, you are not getting a good mesh and could strip the tops of the teeth off. Of course, even if shimmed perfectly, a powerful enough setup will destroy them anyway.
I had my BL Revo (converted 2.5, 9XL, 14 cells) for about a year or so and never had a diff problem.
03.05.2009, 06:38 PM
Originally Posted by mistercrash
If you go and check the exploded views of the T-Maxx Classic, the newer T-Maxx 3.3, the Revo #5308 and #5309, the Platinum Edition Revo and the Slayer, you won't see any of those metal parts in the diffs that are in the diffs of the electric Traxxas vehicles, E-Maxx, ERevo. But of course I can only refer to what I see on the exploded views of those vehicles as I don't have experience with all of them. But I'm pretty sure that those reinforced diffs were introduced only in the electric versions of the Revos and T-Maxxes.
My bad. I could have sworn I saw the nitro ones start to use them as well. Still, the E-Revo and Revo diffs are different. That was the original debate anyway.
03.05.2009, 06:48 PM
Warm beer comin' your way!!!
Guelph, Canada, eh!
03.05.2009, 07:40 PM
It gets confusing because when the original 2.5 Revo was released, and the 2.5r and the 3.3, they all used the same diffs. The new Revo 5308, 5309 and Platinum edition also use those same diffs. The diff carrier for the nitro Revos, the Slayer and the 3.3 TMaxx is TRA5381. The electric version of the diff carrier used in the ERevo, EMaxx is TRA3978 and it comes with the metal spider gear braces. These braces will not fit in the TRA5381 diff carrier of the nitro vehicles. Here is a pic of the nitro diff carrier on the left and the ERevo diff carrier on the right. You can see the recesses in the ERevo diff carrier for the spider gear braces. Surprisingly, if you need to get the output gears TRA5382X, they are the same for both the nitro and the electric. It is basically the output gears used in the EMaxx and come with the center metal ''I bar''. Originally, the output gears part # was TRA5382. Apparently, this has been discontinued and replaced with the EMaxx TRA5382X that includes the I bar and can be used in both nitro and electric diff carriers.
Also when you look at the exploded view of an ERevo diff, it shows a drawing of the nitro Revo diff carrier even if it cannot be used with the ERevo's spider gear braces, that were originally released in the EMaxx
I'm stopping 'cause I'm starting to confuse myself.
03.05.2009, 11:26 PM
I have to ask if you do standing back flips on a regular basis?
Brushless only!
03.12.2009, 07:48 AM
The nitro and electric diffs are different!
I have also killed a bunch of diffs using 40 series tires(mmm combo geared for 38mph). I switched to badlands and havent had a diff issue since. I was blowing the diff cup apart b/c the super gripp/heavy losi super bolt-ons
RC-Monster RC8T
03.12.2009, 04:49 PM
Well I have tpo eat my words! After running a Nitro revo for over a year and an E-Revo for nine months I finally destroyed a diff. As much as I would love the hybrid diffs I just can't justify the price. I was going to get parts and rebuild mine till I looked on ebay. I found complete diffs out of an E-Revo from a chop shop for 10.99 buy it now! I bought 2 complete diffs with shipping for less than $30.....Now it's time to wait for them to come.
03.12.2009, 05:12 PM
well i changed my tire for about a week...wow no destroyed diff since ive do this move  but my driving shaft are tired(new one are in the mail  ).....but everything run well
the best winter tire that ive run,,,maxx mulcher serie40....no baloon effect,light(320grammes tire+rim) and a lot of grip
what size diff shims and where to get them -
03.19.2009, 03:26 PM
after a year i lost a diff after a violent crash bent my rpm arm and drive shaft! I rebuilt with the aluminum drive cup. However id like to shim them to make sure they are tighter - what size shims and where to get?
REVO madman!
03.20.2009, 02:20 PM
http://www.rc-monster.com/forum/show...29&postcount=4 i use shim's from HPI & associated
diff problems -
03.21.2009, 01:32 AM
Originally Posted by E-Revonut
Those big tires aren't helping! Been running my E-REVO since they came out, no diff problems so far. I've run 4, 5, and 6s on my 1515 2.5d. I have only run the talons and badlands which put much less strain on the drivetrain than Big Joes
im with you i race my erevo 2 weekends a month and yet to brake a diff on 3,4,5,or 6s
10.28.2009, 05:57 PM
Originally Posted by madmaxx
Hi mate; woudl you be able to towerhobbies link me to thse shims? cant seem to find them!
Thanks
