squeeforever
squeeforever's Avatar
03.08.2009, 03:58 PM
Originally Posted by mistercrash View Post
You're talking about the axle carriers right? The mod I did are for the Ofna adapters, I didn't do any mods to the carriers. I used the modded Ofna adapters on the old TRX axle carriers, the RPM axle carriers, the RD Racing axle carriers and the new TRX carriers introduced on the Platinum Edition Revo which I'm still running now. The modded Ofna adapters end up costing under $30 total not counting my time. Time spent in my garage is priceless
I was just referring to where you said the most durable and slop free was the RD Racing with the 8mm axles. I was just mentioning the new Tekno kit that is pretty similar, just uses plastic knuckles instead of the aluminum RD uses. Alot cheaper than the RD kit, since its the most expensive, by far.
